Hey all need some advice on some small issues with the woodburning stove we have on the boat. usually it doesnt get that hot so we dont notice it but last night had it filled with coal, compressed logs and one of those 2 hour burn crackle log things so we had flames coming out the top of the chimney and the whole top of it was glowing bright red and so i noticed some problems
around the top of the stove where the chimney is connected the sealant has come off over the past few weeks we only just noticed it the other day. we need to reseal around the chimney and around the top of the stove as you can wiggle the chimney where the sealant has come away. heres a picture to show what i mean
i also noticed fair sized gaps around the door and the glass on the front, should we be concerned about this? iv tightened the glass plane as tight as it will go but there is still a gap
and finally inside there is a big crack in the block at the back which has been there for ages. never had a problem with it but should we replace it?
so can anyone recommend a good sealant for around the top?
should we be concerned about the gaps around the door and glass?
and should we replace the cracked block inside?
we have this stove on everynight to heat the boat so its a bit worrying that we only just noticed these things and need to get them sorted asap before winter really kicks in!
we have an electric carbon monoxide detector 10 ft away and next to the stove we have one of those little co detectors that look like cork and show dark spots when co is high although im not sure how effective it is or if it even works
thanks
thanks
