Any ideas what I could do to ensure the handle doesn't shrink and crack?
Read about this on BB, great shame.
To uniformly stabilize or plasticize wood through to the core (Even on thin scales) it can take at least several hours...and these do not look like thin scales.
To date their is no quick process that will uniformly saturate wood to the core.
The wood / scales I process are subject to chemical formula I developed and also vacuum, pressure and heat....across a several day period, sometimes weeks for hardwood....this ensures sufficient penetration.
The process also fills in the cracks too
Have also developed a technique for stabilizing wood after it has been fitted (Even older blades).....
The danish oil treatment mentioned should suffice if you tweak your process a little
I would be inclined to place the blade in the oil and warm the oil slowly to a moderate but not a 'hot' temperature. Maintain the temperature for as long as possible up to an hour or so. Then switch off the heat and allow it to cool slowly.
The wood will swell, pores will open and it will take in more oil that if treated with cold oil.
Allowing it to cool slowly will help trap oil....
Recommend removal of the stabilized 'shell'...if the wood is allowed to swell too much it may induce a split.
Then it is a matter of letting the oil firm up, polish and hey presto.....
An alternative is to replace the handle but.....what gorgeous wood...and it can be stabilized fully in situ no problem
Put it this way, if they are being sold off I'll be buying loads of them and treating them
Tom
