Wood can filter nanoparticles from water.
Pattree
Jul 19, 2023
4,509
3,214
79
My weekly comic, New Scientist, has an article this week about water filters made from slices of wood.
Water filters made from untreated wood can remove more than 99 per cent of particles, taking out many harmful bacteria and microplastics.
I’m not sure how ethical it might be to copy the article here and a link would require a subscription.
Basically filters made of disks of wood, 50mm in diameter and 1mm thick take out everything above 100nm.
This includes microplastics and most bacteria but not virii.
The article does not say how many discs are used at a time but it implies just one.
The researchers tested slices of yellow poplar (Liriodendron tulipifera), European beech (Fagus sylvatica), Douglas fir (Pseudotsuga menziesii) and silver fir (Abies alba). Two were clear leaders: European beech removed 99.7 to 99.9 per cent of nanoparticles and silver fir removed 99.3 to 99.7 per cent. But water flowed quicker through beech wood, so it was the researchers’ preferred choice.
Perhaps someone can take this up.
We can’t do the detailed before and after testing but is there something that we can detect by smell or taste that would do the job?
That’s interesting. Makes sense I suppose due to the tiny hollow vessels remaining in the wood.
I remember being surprised how effective activated charcoal derived from coconut shells is for filtration, of course it’s the long rods I use for my mains drinking water filter, but the specs are crazy. It kind of blew me away that 3 grams of activated coconut charcoal has the surface area of a football pitch, and a kilo has a surface area of a million square metres.
Reactions: Ozmundo and MrEd
I do not have any water filtering system but I thought I’d make a wooden one out of interest. Getting a cross cut slice down to 1mm thick won’t be easy. I’ll probably settle for bigger, thicker and slower.
Could you plane a mm thick layer and then cut it out in a circle? I have in mind those Japanese masters that plane enormous lengths down to ultra thin paper style shavings!
Reactions: Ozmundo
Cross grain 1mm is going to be very brittle, I think larger but longer is more realistic.
I’d be interested to see how you get on
It does make sense, given end grain wooden chopping boards being recommended over plastic/glass/met for their anti microbial properties, as well as being better for the blade. I think partly due to the same capillary action that @Nice65 mentioned above.
Reactions: Ozmundo
I’m thinking nothing more complicated than a plastic bottle with most of the bottom cut out, two big leather washers and a load of little bolts over a funnel into another bottle.
The article doesn’t mention “flavour”.
They are suggesting dried wood.
Beech might be OK.
Pines might be interesting flavours.
Oleander - best not!!!!
I realy love this sort of knowledge. How much of a long term solution would this be i wonder? Wood in water will rot and have moulds, slimes, etc growing on it, so I'm wondering how safe it would be over time.
Good point, let’s see.
I have a couple of projects on the bench right now but this is going to be one to try.
A local guy is selling wooden offcuts as fire wood. It looks fine grained. I’ve ignored it up till now but it’s just the right size cross section. No one said the filter had to be round :)
Reactions: slaine_23
Nope!
I’d completely forgotten it.
Thanks for reminding me. It’ll have to join the project queue. I’m in flute and cooking pot making mode right now.
Seems to be other, earlier, research involving dried wood disks dipped into ethanol then used as filters or using sawdust. This latest approach seems to be simpler.
Beech is the favoured wood apparently.
Should be some felled beech around after the storms a few months ago.
Bum - he’s not there any more:confused:
I’ve got some pipe that a wooden disc could fit into.
As soon as I find a spruce bough with approximately the right diameter I’ll make it.
Am thinking along similar lines. Maybe white 50mm maybe 100mm pipes, with connectors - maybe 50mm wood slice in a connector, pipe on top of that - sort of a letter H affair with the bar of the H being wood.
Have some beech, need to figure out how to dry, size and cut it.
Be interesting to read the actual paper.
For me, I hope the slicing will be ok, using a band saw. The shaping of the piece to the right shape and diameter need to figure out.
Wondering if they tried birch, given its properties.
I’ma bit bushcraft busy right now.
Let us know how you get on.
I’m not sure yet how to cut 1mm slices - I’ll probably cut 3 - 4mm slices and just be more patient.
