Hi Tom,
As has been pointed out it is more than likely that those are made from mild steel. However if you are new to the knife making game then use this as practice steel.
You will need to grind or file it to shape first but be careful if you should choose to attempt a heat treatment as the steel looks galvanised to me. Heating galvanised steel causes zinc fumes which are deadly poisonous.
Once you feel more comfortable with shaping your blade, buy in a known steel like the 01 linked above. 01 is generally regarded a good place to start as it is a fairly simple high carbon steel that is quite forgiving.
All the best
Andy
