I bought this unit last week and I have only just got around(and had some sun)to test it. I have it sat in the only patch of sun in the house at 1pm.
I have plugged in my IPad Air and if the panel is positioned properly it charges normally but if a shadow goes on the panel or the angle is a bit off it says that it's not charging and the device may not be compatible. But...it does still charge and with the weak sun coming in through the patio window with a bit of shadow I'm getting up to 750 mA into the iPad.
I bought the digital readout from eBay for a couple of quid which just plugs in the USB port before the device being used. It gives both the voltage and current going to the device. At the point of the picture being taken you can see what's happening but position the panel better and the voltage jumps back to just over 5 volts and the current goes up too!
This is only the first test but it seems to do the job nicely. I think it was about £40 delivered from Amazon if anyone is interested? I will do more tests as and when I can.
That volt/amp meter is so cool and works with any usb device so you can see exactly what's happening. As they are so cheap I can see me getting a few for general use?
