Travel Tap / Water Filter - Pull Top - 800ml - 1600 Litres [The New Model]
ADz-1983
Oct 4, 2012
1,603
11
Hull / East Yorkshire
The Travel Tap ‘Pull top’ 800ml pure water filter bottle
Makes water safe and clean tasting for safe hydration using untreated water or treated water - wherever you are.
Key features :
Simple to operate - Instant use - purifies and filters water
Removes threat from pathogen including E-Coli cryptospridium , viruses, protozoa, Anthrax etc
( UK Environment Agency NLS and worldwide tested filter system)
Removes groundwater chemicals including pesticides and herbicides and sediment and even treated water chemicals from domestic or municipal supplies making water taste as bought bottle mineral water.
Features :
'Autoshutdown' when filter life end reached - up to 1600 litre use. Can be used stored and reused again and again. Full user guide supplied. Replaceable grill filter cartridge allows all water use.
To Use: Fill bottle with untreated or treated water
– screw cap on tight , pull up spout and instantly use .
Works by :
Gently squeezing bottl;e processes pure filter water to instantly drink from or fill cups or cooking vessels and even flush wounds. Often forgotten essential device for personal hygiene, cleaning teeth (instead of using untreated water).
Choice of purchsing options for your use supplied with advance worldwide use filter cartridge or insulating carrier or a combination
Insulating carrier and lanyard
Optional insulating carrier with fully adjustable lanyard provides protection and insulation and Travel Tap 'Pull top’ can process water without removing from the carrier.
These are personal safe water drinking devices that have been proven to remove threat from drinking water contaminants and make treated water quality better by removing taste and taint.
Using: A little patience is required and resistance expected when using a micro filter system just like drinking from a large straw.
Ensure cap is on securely – these systems are ultralight 150g and use no pumps or chemicals.
MULTI USE:
Enables use for any assured liquid when filter cartridge is removed.
(If using for any liquid other than water the bottle should be rinsed with
clean water prior to reusing with the water filter cartridge).
Used on a few trips but its good for 1600 Liters. Will be hygienically cleaned before sending.
£20 Delivered to UK
