some results from the us military test on commercial water purifiers:
http://chppm-www.apgea.army.mil/WPD/CompareDevices.aspx
alex
alex
Martyn said:I wonder why no UV purifiers in the tests?
anthonyyy said:Actually they seem to have tested a "uv pen" (about 6 from the bottom) but all the boxes are marked with an "X", whatever that means.
Means we do not expect the device to consistently provide adequate protection from microbial pathogen groups. This is based on available data, lack of data, and/or general scientific knowledge of the treatment technology. A device containing an X requires additional treatment to minimize the risk of illness from waterborne pathogens.
Stuart said:I dont agree with their views on iodine either, they seem to be working on the basis that if they have no specific data from the EPA on effectiveness against cryptosporidium, Giardia, etc (ie the EPA have never tested it) then they automatically mark it as ineffective, which essentially discredits all methods utilising iodine
Stuart said:I'm not sure I agree with their findings, I have been involved in testing a number of water purification devices over the years and some of the solutions that I class as the best are rated poorly there, where as conversely one of the solutions which i ranked as least effective scores quite highly there.
I wouldnt recommend that anyone use this data to make a decision on what water purification system to use
Pete E said:Where a device has an X against it, click on "more information" tabs in the far right columns and they explain why its failed and what is needed to remedy it ie additional treatment.
Pete E said:Stuart,
Would you mind explaining in a bit more detail how you carried out the tests and for whom????
With regards the US Army Tests, you need to read the blurb fully to understand what they are saying...The rating reflect the stringency of adherence to the specified testing program as much as to the effectiveness of the unit. They also prefer the tests to be carried out by an independent body rather than the manufacturer themselves.
Martyn said:Testing really isn’t difficult. Deliberately infect a sample of sterile water with a known dilution of the organism of your choice, filter/sterilise it with your device/chemical, then culture & microscopy for presence of organisms. Test 100 samples to get statistical significance.
No brainer really. Cheap too. Pretty much any small public health laboratory could do it easily.
Pete E said:Stuart,
Thanks for that, very interesting...It seems that my swee****er filter is now part of the MSR group. I am pleased to see it came out tops on all the tests...alco141 said:some results from the us military test on commercial water purifiers:
alex
Mikey P said:equipment a lot cheaper)
Was this system tested in the series of tests mentioned at the start of this thread?
Stuart said:In some cases I undertook the evaluations for the manufacturer (or the UK distributor) of the device, in other cases I was tasked with testing devices by companies considering marketing them.
I was not directly involved in any laboratory testing (I am not qualified to do so), my aim was to determine real world reliability and function by testing them under difficult conditions and harsh environments (jungle, desert etc)
I cannot disclose exactly for whom I undertook the testing, what the results were and which manufactures were involved as this might breach certain non-disclosure agreements, I can however tell you which devices I choose to use personally
Stuart said:Exactly, so why havent they simply tested it, rather than discrediting a universally accepted method because that havent undertaken a simple test
Pete E said:Mikey,
In these particular tests, it gets the top three ticks for dealing with Bacteria, Virus Giardia, but an X for Cryptosporidium parvum.
The site then goes on to give the advantages/disadvantages of this product as:
"Advantages
* Independent testing using the USEPA Guide Standard and Protocol for Testing Microbiological Water Purifiers confirms the device consistently provides 6-log bacteria, 4-log virus, and 3-log Giardia cyst reduction when used as directed.
* Small and lightweight.
* Inexpensive to use.
* No adverse health effects expected in healthy adults from short-term use.
Disadvantages
* Does not consistently provide adequate Cryptosporidium reduction when used as directed. Using the overkill option dose (8X normal dose) and waiting 4 hours will ensure adequate Cryptosporidium reduction.
* Does not reduce or remove particulate matter.
* Can impart chlorine taste and odor. "
I suspect the reason they fail it for use against Cryptosporidium is that the four hour over kill dose is needed as opposed to normal operation and that there is a grey area that people have to decided to undertake this additional step ie they have no way of knowing if the water they are treating has Cryptosporidium present or not....
Pete E said:Therefore I would so the infomation while extremely useful, its needs to be used with care....
Regards,
Pete
