Hafting a Stone Blade the Old-Fashioned Way
by storm
There are many ways to attach a handle onto tools. Wanting to expend the least amount of energy possible in stone age endeavors, I use vast amounts of energy experimenting with various techniques. Some work, others would work (if someone else performed them...). Heres one method that I prefer because, well, I have little command of carpenter-ic common sense, a weak grasp on thinking and planning ahead, and little patience for crafting fine notches that snugly, custom-fit a randomly-contoured stone blade. If you have any questions, I can be reached at storm@stoneageskills.com.
It all begins with The Stick. I chose a hank of Big Leaf Maple because it is soft and therefore easier to split with stone age tools.
Im a big fan of letting nature do the work for me. Rather than chop away with stone tools to reduce the ends of this tool handle, its easier to burn them. You might be wondering why Ive built my fire on top of a chunk o wood. Well, this experiment ran concurrently with my first attempts to coal-burn a larger container for Stone Boiling. Notice the flames? Dont Do That. The greater heat only serves to check and split the future bowl. Effective coal-burning involves coals, not flames...
Gettin there!
To smooth the end (I am going to put my hand there, you know) I am using a chunk of quartz, which has a bed of tiny crystals along one side (in the photo you can see an edge-on view of the crystals on the right side of the rock). This tool works great at scraping the ashy residue off the wooden handle.
Time to reduce the other end. Maybe you notice the cracks forming on the lip of the coal-burned bowl. Let that be a lesson to me (but the bowl did hold a gallon of water and I ended up stone-boiling in it a couple dozen times!).
Heres a nifty sanding invention that utilizes a strip of horsetail (Equisetum hyemale), which I glued to a piece of Yellow Cedar with deer hide glue. This works well at finish sanding.
A dried piece of Deer Hide Glue. While living on the Olympic Peninsula of Washington State, I was lucky enough to come across numerous dead deer. Strip the hide off, de-hair it by soaking for four days in a solution of four gallons water and one gallon wood ash, then boil the hides in fresh water for 8-12 hours. The collagen and other proteins dissociate from the skin and rise to the top of the water. Scrape this glue off the top and let dry. Deer hide glue is notorious for molding quickly. I ended up putting the lot into a food processor (not mine, thankfully) and grinding it so that the resulting tiny bits would be able to dry through-and-through.
Finished with the burning and sanding.
Part Two awaits you...
by storm
Gettin there!
